MAC address list transfer
Matt10669
Matt10669 Posts: 27 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment Fourth Anniversary
I replaced my USG1100 with a new USG FLEX700. Is there a way to transfer the MAC filter list that I populated in the SSID management?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,399 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Matt10669
    (1) You can provide the configuration file of the USG1100 to us via private message for transformation.
    (2) Alternatively, you can manually add the MAC filter list using the Web-GUI or on the USG Flex 700.
    (3) You can also add the MAC filter list to the configuration file of the USG Flex 700 and apply it.
    Thanks.
  • Matt10669
    Hi, thank you for your answer. Can you explain better the point 3?
  • Zyxel_Jeff
    Hi @Matt10669
    Let me explain it more clearly to you.
    Step 1: Copy the MAC addresses from the USG1100's configuration file.
    Step 2: Paste these MAC addresses into the USG Flex 700's configuration file and save it as a new edited configuration file.
    Step 3: Apply the new edited configuration file to the USG Flex 700.
  • Matt10669
    how can I open and edit a configuration file?
  • Zyxel_Jeff
    Hi @Matt10669
    You can open and edit the .conf file with any text editor application. But if you still have problems with this method, please provide the USG1100's configuration file to us and we can transfer the configuration file for you. Thanks.
