What firewall rules are needed to allow L2TP over IPSEC from Windows 11
VPN_Newbie
VPN_Newbie Posts: 14  Freshman Member
edited November 2023 in Security
Hi
I have a USG60 configured to allow VPN connections from Windows 11 via WAN2. All is fine until I enable the Security Policy Control, i.e. I turn on the firewall. What firewall rules are needed to allow the VPN to connect.
*I did have to create a pair of routing policies to allow me to browse the local LAN and internet which I've attached below.
«13
    PeterUK Posts: 3,647  Guru Member
    WAN to Zywall
    UDP 500
    UDP 4500
    UDP 1701
    protocol 50
    VPN zone Ipsec_VPN to Zywall
    UDP 500
    UDP 4500
    UDP 1701
    protocol 50
  • VPN_Newbie
    Hi
    Partial success. The VPN now connects, but no traffic can pass through. I'm guessing I need another rule to allow traffic to pass. I've tried the following.
    So you should be able to ping the LAN over the VPN?
    Are you looking for the VPN to do internet? Or just to LAN?
    Disable them routing rules and make these.
    For LAN
    incoming VPN tunnel
    destination LAN subnet
    next hop auto
    For internet over the VPN below the rule above you need
    incoming VPN tunnel
    next hop WAN
  • VPN_Newbie
    Hi
    I'm not able to ping the Zyxel in the current config, or any IP on the LAN.
    I'll have a go of your suggestions above.
    just to add
    For LAN
    incoming VPN tunnel
    SNAT none
  • VPN_Newbie
    Hi
    It didn't work. I still can't ping the Zyxel or anything on the LAN.
    I've attached the policy below.
    Can you go to maintenance > diagnostic > network tools > PING IPv4 to a device on your LAN if no ping its a firewall on that device thats blocking it
    Also check the zone of the VPN settings is the right one
    and is the IP pool of the VPN not in use by other interfaces?
  • VPN_Newbie
    For some reason, when I post the result of the ping, it gets blocked, but not if I post a picture of it.
  • VPN_Newbie
  • VPN_Newbie
