How to setup internal VLANs on USG Flex 100H
DJWindows
DJWindows Posts: 4 image  Freshman Member
Hello Folks,
I'm pretty new to Zyxel USG Flex H-Series so I need Help in setting up VLANs.
I know the basics of VLANs and how they are handled but I'm comming from total different vendors (Sophos/Cisco).
Setup goal:
The LAN-Interface (ge3) has the subnet 192.168.10.x . Additional to that I need 2 VLANs on this interface:
- 192.168.110.x
- 192.168.120.x
In the end the subnets 192.168.10.x and 192.168.120.x have to communicate with one host in VLAN-Subnet 192.168.110.x but not between each other.
All tutorials I've found relying on USG 100 but not 100H and the interface seems to be totally different.
So please - if anybody could help me with that soon would be perfect.
Cheers
Sebasian
    PeterUK Posts: 4,589 image  Guru Member
    edited December 2023 Answer ✓
    Yes the new H models have a whole new layout vs old models
    all ports are configurable meaning you can have any port be WAN (External) or LAN (Internal) with VLAN on top WAN or LAN.
    I guess you have managed to log n to the Flex? Port setup for WAN you can use the LAN port you logged in to you can change that IP to 192.168.10.1 then re login
    best go to object > Zone and make some zones like VLAN110 and VLAN120
    then go to interface under Internal +add
    interface type VLAN
    name like VLAN110 and VLAN120
    port you logged in as like P3 for the VLAN to be on
    zone VLAN110 and VLAN120
    VLAN ID 110 or 120
    fixed IP
    DHCP to how you want
    apply to the same again for the other VLAN
    by default SNAT is enabled so you should not need to added router rule but can if needed
    policy control by default LAN to any may need to be changed to how you like
    you can have rules like
    LAN to WAN
    VLAN110 to WAN
    VLAN120 to WAN
    all zones isolated
    Then add to say
    LAN to VLAN110
    VLAN110 to LAN
    to allow traffic between zones
    interface type VLAN
    VLAN ID 110 or 120
    fixed IP
    LAN to WAN
    VLAN110 to WAN
    VLAN120 to WAN
    all zones isolated
    Then add to say
    LAN to VLAN110
    VLAN110 to LAN
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @DJWindows ,
    Greeting Forum, and thanks PeterUK.
    Please kindly follow PeterUK statements and feel free to raise questions if any concerns.
    Thank you
