Flex 700H reboots and issue
Hy team.
I'm having serious issue with two 700H firmware 1.10(ABZI.1).
One of them had to go out of production and I had to buy a Flex700 and the problems were gone.
I have random reboots and system crashes.
One of the issue is that it seems that the device works but it does not assign DHCP and you cannot access it. I set a static IP and I can't access it via GUI. In console I can ping all interfaces, but the firewall is still blocked. Restarting solves the problem.
Another issue. Sometimes, when I connect a Zyxel 1 meter DAC or other DAC cable to the SFP+ module it restarts automatically. This is a problem because my ISP works with SFP+.
I have a video where the error appears.
With a cable in the console the error does not appear, it just restarts.
Another issue is that I cannot use any Transceiver because my 700H cannot work with them.
Another issue is that through SFP+ and DAC between switches is not correct. The vlan assignment is incorrect. By switching to copper the problems were solved.
I think the problems are in the SFP+ module
Since October it has been one problem after another....
I have tried to open support tickets but I have no response from Zyxel and I am desperate.
I have a 700H in a box and the licenses are running and another one in production that the customer is starting to get angry.
I need help, urgently....
Its a whole new OS so problems are going to happen I guess the SFP+ module where not tested all that well sadly...
as a workaround for your ISP by SFP+
https://www.amazon.co.uk/10Gtek-Ethernet-Converter-1000Base-Tx-Transceiver/dp/B01MG48FD5/ref=sr_1_9
Peter, it's what I do but this cooper makes me lose internet packages. The router is an Accedian and it is special. Just like Cisco.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.2K Security
- 93 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
