Remove an Static IP entry on a LAN interface gives error
GerSom
GerSom Posts: 2 image  Freshman Member
edited January 2024 in USG FLEX H Series
If I try to remove an Static IP entry on a LAN interface I get:
CLI Number: 17
Error Number: -4005
Error Message: 'DHCP pool does not exist.'
Everything I try to do to resolve this, does not solve the problem. There are entries in de the tables that work!
Can you help?
  • GerSom
    Hi there,
    I solved the issue by removing the trouble giving entry in de IP/<AC binding menu option. Gives also the option to remove an entry out of the Static IP Table and that remove there worked.
    Thanks!
  • USG_User
    USG_User Posts: 400 image  Master Member
    I reactivate this old thread. We tried to release an assigned IP address on our USG Flex 700 (v5.38). Therefore we went to
    CONFIG > Network > Interface > Ethernet > Static DHCP Table
    and tried to remove the corresponding MAC/IP entry from static DHCP table of the affected subnet. Unfortunately this was not possible and USG returned the o.m. errors.
    To solve it, we still have to remove the IP/MAC entry in
    CONFIG > Network > IP/MAC Binding > affected Subnet
    first, although the affected subnet is not activated for IP/MAC Binding!
    Is it a bug or a feature?
