Getting PCI Compliant have to diable TLS 1.0
I failed PCI Compliant test they want me to disable the TLS1.0. I cant seem how to disable this.
This is what they said I need to do.
Any help would be gratefully appreciated
Disable the use of TLSv1.0 protocol in favor of a cryptographically stronger protocol such as TLSv1.2. The following openssl commands can be used to do a manual test: openssl s_client -connect ip:port -tls1 If the test is successful, then the target support TLSv1 |
Mark thanks for the pdf. My next question would be how do I open a console session with the gateway. Thanks
depending on the model and firmware you can acces console trough the webgui its in the top right of the screen.. Its newly introduced in the 4.32 firmware..
otherwise download putty
https://the.earth.li/~sgtatham/putty/latest/w32/putty.exe
run it on a pc wich is in the local lan of the device
fill in the local ip adress off the device and choose SSH
It will prompt you as follwing click yes
fill in de admin and password
and then you have opened the console line interface..
I see on the upper right hand corner of the zyxel interface it has CLI button and when I click on it shows a trash can then clear and underneath it shows ### CLI start and then it populates to 1-7 commands. Is this where I would type in the command for disable the TLS 1.00
Dear @Snowtoy
You should better call us in support monday.. Don't get me wrong but it seems you do not have much experience with our products.. So if you call in we can do this for you and you can learn how to do it next time..
Wich country are you living in? based on that i can provide you with the right phone number.
Or you PM me your number and i will get in contact with you ..
@Snowtoy
Are you using a mac or a PC?0 -
PC with Win 10 Pro and Living in the USA0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
