Drop SSL VPN on Wifi
Glonet
Glonet Posts: 1 image  Freshman Member
edited April 2021 in Security
My client is using SSL VPN on a ZyWall USG 200. On the cable there is not issue. When he is trying to connect with the wifi the VPN connects for a few seconds and then drops. I installed the latest SecuExtender and reinstalled my Wireless Card. Other clients have no issues.
  • Blabababa
    Blabababa Posts: 151
    image  Master Member
    "Other clients have no issues" do you mean other users don't have certain issue even when using wifi to build the SSL VPN tunnel? If so, maybe you can cross check on the wifi related parameters in the operating system.
  • kaestormy
    kaestormy Posts: 8
    Where you able to get this corrected?  Sounds similar to what we are currently experiencing.  Thanks
  • [Deleted User]
    [Deleted User] Posts: 118
    5 Answers First Comment Friend Collector Fifth Anniversary
    image  Ally Member
    @Glonet
    Please share the content of the secuextender log file to see if we can determine an issue. (find it on the root of the c:\ drive
    Please first initiate a normal SSL VPN tunnel when its working
    And then do a FAIL SSL VPN tunnel
  • kaestormy
    kaestormy Posts: 8
    sent you a private message with log thank you
