USG FLEX H Advanced DHCP functions not available and more
When setting up my new USG Flex 200H i cant find the Advanced DHCP functions setting.
The "old" USG FLEX 200 was able to set this function however the H doenst show this function, how do i get this fixed.
I need to set DHCP code 43
Also the option FQDN is missing when adding addresses under object, the device seems not finishend yet
more info here
more info here
Hi PeterUK
Is it possible to set DHCP option 66 via cli command?
If it's possible, can you send me the commands to configure it in 500H ?1 -
#edit running
#vrf main main dhcp server subnet {your dhcp subnet} dhcp-options user-defined <value>
<uint8> Max count: 15.
ZLD dhcp server option 0 user defined, user-defined
[code] [type] [value]
#commit
2 -
Since update 1.20 the Advanced DHCP functions are available only not code 43 😵 why? in the normal flex series this works.
Via the console option 43 is possible 🤪
I have an USG FLEX 500H and use rule with EDQN is still not possible. I've installed the last fimware.
Can you please provide a solution?
In 06/2025 with firmware 1.32 can use different code option but 43 still not aviable, why?
By contradiction 41 can use it.
- 240 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
