Filter package-trace for multiple port and for a specific host
I try to filter the traffic between the WAN port of a Zyxel Flex 500 (firmware v5.37) and a host (external IP address) for multiple ports, but the following commands shows me the traffic of all kind of ip addresses instead of only one.
packet-trace interface WAN extension-filter match-host 62.x.x.x 62.x.x.x match-port 500 4500
packet-trace interface WAN host 62.x.x.x extension-filter match-port 500 4500
what am I doing wrong?
To filter package-trace for multiple ports and a specific host, ensure to accurately specify the host's IP address and the desired ports in the command. The correct format should be: "packet-trace interface WAN extension-filter match-host [host_IP_address] match-port [port1] [port2]." For example, "packet-trace interface WAN extension-filter match-host 62.x.x.x match-port 500 4500." Make sure to replace [host_IP_address] with the actual external IP address of the host and [port1] [port2] with the desired port numbers.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
