USG FLEX H Advanced DHCP functions not available and more
Xelvin
Xelvin Posts: 2
First Comment Sixth Anniversary
image  Freshman Member
edited February 2024 in USG FLEX H Series
When setting up my new USG Flex 200H i cant find the Advanced DHCP functions setting.
The "old" USG FLEX 200 was able to set this function however the H doenst show this function, how do i get this fixed.
I need to set DHCP code 43
Also the option FQDN is missing when adding addresses under object, the device seems not finishend yet
    PeterUK Posts: 4,742
    image  Guru Member
  • qsystem
    qsystem Posts: 3
    Hi PeterUK
    Is it possible to set DHCP option 66 via cli command?
    If it's possible, can you send me the commands to configure it in 500H ?
  • WJS
    WJS Posts: 156
    5 Answers First Comment Friend Collector Fourth Anniversary
    image  Master Member
    #edit running
    #vrf main main dhcp server subnet {your dhcp subnet} dhcp-options user-defined <value>
      <uint8>              Max count: 15.
                           ZLD dhcp server option 0 user defined, user-defined
                           [code] [type] [value]
    #commit
  • Xelvin
    Xelvin Posts: 2
    edited April 2024
    Since update 1.20 the Advanced DHCP functions are available only not code 43 😵 why? in the normal flex series this works.
    Via the console option 43 is possible 🤪
  • davide_v
    davide_v Posts: 2
    I have an USG FLEX 500H and use rule with EDQN is still not possible. I've installed the last fimware.
    Can you please provide a solution?
  • Alex_91
    Alex_91 Posts: 58
    First Comment Friend Collector Eighth Anniversary
    image  Ally Member
    In 06/2025 with firmware 1.32 can use different code option but 43 still not aviable, why?
    By contradiction 41 can use it.
