50 days link goes down to 100Mb
So this has happen
about 2 times and happens about every 50 days!
I have the ZyWALL 110
WAN 1 port to bridge with DMZ on V4.32(AAAA.0) the WAN 1 port is
connected to port 1 on ZyXEL GS2210-24 on V4.50(AAND.2) and between
the two is where the link drops to 100Mb.
I can't see it being
the cable but happy to be wrong.
So what fixes this is a
simple unplug and replug of the ports and that gets it back to 1Gb
for around 50 days. So it happened again so I tried something new
logged in to the ZyXEL GS2210-24 and tried changing the speed /
duplex setting of port 1 to 1000M / full duplex this resulted in no
connection changed back to auto-1000M linked at 100Mb so rebooted the
ZyWALL 110 and is back to 1Gb.
I'm hoping its a
firmware issue but it could be a hardware fault but seems odd that
its stable for around 50days.
What should I do next should my uptime last for it to happen again?
Regarding to your description,
we have not heard the similar case on USG series and GS2210-24 before.
Therefore, we want to clarify which is hardware issue or not, can you shift the other port to connect(on Switch and USG).
However, if the issue occur again, can you please dump the information via console and private message to me for our analysis.
On GS2210-24, type comment: GS2210# show tech-support
On Zywall, type comment: Router(config)# show port status
Charlie
So you want me to keep the same setup now or do you want me to change ports now? I can't change ports on the ZyWALL 110 but can change the port on GS2210-24.
@PeterUK
You can keep the ports on zywall110, but please change the port on GS2210-24.However, if the issue occur again, can you please dump the information via console and private message to me for our analysis.
Charlie
Its been 16 days on the same ports so what I will do is wait for it to happen again and post the logs then change the port this way you get to see it happen if you don't mind.
OK after thinking about its better if I do change the port on GS2210
But I do find it odd it takes around 50 days for it to drop to 100Mb maybe a custom link negotiation?
@PeterUK
Regarding to this case,
normally, the device will keep the 1000Mbps on auto negotiation.
Therefore, we need to analyze the log message to find out which part cause the speed down to 100Mb.
Charlie0 -
What I have also done is connected another bit of equipment to port 1 of the GS2210 thats known to be fine so we see what happens in the next 50days...its going to be a long wait...
Just to update my post here
The link went down to 100Mb but it don't take 50days it happened in 8days on port 7 of the GS2210-24 this it starting to look like the port on the ZyWALL 110 is failing? Or maybe a cable fault so for the time being I'm keeping things the same unless told what to do next in the mean time I have updated the ZyWALL 110 to V4.33 Its likely not going to make any difference but I can hope.
But its really odd that for the 8days it was stable and even when it drop to 100Mb it was stable without packet loss except when it dropped from 1Gb to 100Mb but I would of expected for a failing port to show more packet loss?
Up late and found a bit of packet loss but it didn't link down and this shows up from GS2210 logs
7 Feb 02 01:00:52 DE interface: Port 7 link up
8 Feb 02 01:00:48 DE interface: Port 7 link down
9 Feb 02 01:00:48 DE interface: Port 7 link up
10 Feb 02 01:00:48 DE interface: Port 7 link down
11 Feb 02 01:00:42 DE interface: Port 7 link up
12 Feb 02 01:00:42 DE interface: Port 7 link down
13 Feb 02 01:00:41 DE interface: Port 7 link up
14 Feb 02 01:00:41 DE interface: Port 7 link down
15 Feb 02 01:00:41 DE interface: Port 7 link up
16 Feb 02 01:00:41 DE interface: Port 7 link down
17 Feb 02 01:00:38 DE interface: Port 7 link up
18 Feb 02 01:00:38 DE interface: Port 7 link down
19 Feb 02 01:00:38 DE interface: Port 7 link up
20 Feb 02 01:00:38 DE interface: Port 7 link down
21 Feb 02 01:00:37 DE interface: Port 7 link up
22 Feb 02 01:00:37 DE interface: Port 7 link down0 -
more packet loss and this in logs link stayed up to 1Gb
1 Feb 04 17:26:49 IN authentication: SSH user admin login [IP address = 192.168.255.250]
2 Feb 04 17:25:50 DE interface: Port 7 link up
3 Feb 04 17:25:50 DE interface: Port 7 link down
4 Feb 04 17:25:43 DE interface: Port 7 link up
5 Feb 04 17:25:40 DE interface: Port 7 link down
6 Feb 04 17:25:36 DE interface: Port 7 link up
7 Feb 04 17:25:33 DE interface: Port 7 link down
8 Feb 04 17:22:53 DE interface: Port 7 link up
9 Feb 04 17:22:50 DE interface: Port 7 link down0 -
Today I changed the cable out and put the ZyWALL 110 back to port 1 on the GS2210-24 it seems random and by moving the cable about made it worse so I'm hoping its the cable.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
