Security policy FQDN
Alex_91
Alex_91 Posts: 64
First Comment Friend Collector Eighth Anniversary
image  Ally Member
edited April 2024 in Security
by following this Microsoft link to allow access the Outlook App to Exchange OnPrem:
I see that you need to enable fqdn to allow access.
Am I wrong or Zyxel firewalls not resolve the IP class?
I add this roule:
sometimes rule not working
    PeterUK Posts: 4,841
    image  Guru Member
    edited April 2024 Answer ✓
    Can FQDN resolve IP subnet?
    No I FQDN can lookup the IP's of a DNS name bbc.co.uk
    151.101.0.81
    151.101.64.81
    151.101.192.81
    151.101.128.81
    You can do *bbc.co.uk for WILDCARD for subdomain by DNS that happens LAN to WAN for the IP's it gets
  • WJS
    WJS Posts: 156
    5 Answers First Comment Friend Collector Fourth Anniversary
    image  Master Member
    Those addresses are server need to access which means this is outgoing traffic.
    I thought you need a rule is LAN → WAN , dst: AppOutlook
  • Alex_91
    Alex_91 Posts: 64
    image  Ally Member
    Let's leave aside for the moment the question of whether it is needed (for incoming or outgoing access).
    Example: outlook.cloud.microsoft -> 13.107.6.152/31 + 13.107.18.10/31 + …
    or is it really necessary to specify the various subnets manually?
  • WJS
    WJS Posts: 156
    image  Master Member
    It can. It works with FQDN objects.
  • Alex_91
    Alex_91 Posts: 64
    image  Ally Member
    from specific firmware or what?
    I can confirm that if I enter the various IPs manually in the rules (13.107.6.152/31, 13.107.18.10/31, 13.107.128.0/22, ...) the application works.
    If I leave the FQDNs alone (outlook.cloud.microsoft, outlook.office.com, outlook.office365.com) the app doesn't work.
  • WJS
    WJS Posts: 156
    image  Master Member
    FQDN object should work with now alive appliance.
    But sounds like you have FQDN object which mean your firmware should support this feature.
    Maybe try the latest firmware ?
    image  Guru Member
    151.101.0.81
    151.101.64.81
    151.101.192.81
    151.101.128.81
