The vlan config page on the gs1200-8p v2 only shows 4 vlans
How do I check and update the config on the other vlans I have created? I have vlan 5 and 100 created but they don't appear
Hi @mehari1024
You may want to consider upgrading Firefox to the latest version, such as 125.0.2, and see if the scrollbar becomes visible. Also, ensure the device is updated to the latest version, 2.00(ABMF.3)C0.
Additionally, clearing the browser cache might also resolve the issue.
In our local testing with Firefox, it displays perfectly, as shown in the screenshot below:
Nami
If you go with the mouse cursor on right side of the panel it will appear a scrollbar:
Thanks, It is very small and only really shows when the mouse goes over the edge of the window, I'm using firefox 125.0
Hi @mehari1024
Nami
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
