USG Flex 200 doesnt allow windows 11 IPSEC Phase 1 conection
AntonK
AntonK Posts: 5
image  Freshman Member
Hi my USG Flex was configured for low security ipsec vpn with linux clients
USG Flex 200 doesnt allow windows 11 IPSEC Phase 1 conection:
"Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA1 PRF, HMAC-SHA1-96, 384 bit ECP, AES CBC key len = 128, 256 bit ECP, 2048 bit MODP, 3DES, 1024 bit MODP, HMAC-MD5 PRF, HMAC-MD5-96, DES, 768 bit MODP; )."
so what can be done on usg flex side or windows 11 side to match connection - there is some force reg keys for regedit but no info about it…..
«1
  • AntonK
    AntonK Posts: 5
    Sorry, phase 1 passes, stuck at phase 2 without any detail info
  • zyman2008
    zyman2008 Posts: 248
    50 Answers First Comment Friend Collector Eighth Anniversary
    image  Master Member
    Hi @AntonK ,
    Using power shell command to change the phase 1 & phase 2 proposal.
    1. Show phase 1 & phase 2 proposal of VPN connection
    Get-VpnConnection -name "YourConnectionName" | Select-Object -ExpandProperty IPsecCustomPolicy
    2. Set phase 1 & phase 2 proposal of VPN connection
    Set-VpnConnectionIPsecConfiguration -ConnectionName "YourConnectionName" -EncryptionMethod <IKE  Encyption> -IntegrityCheckMethod <IKE Authentication> -DHGroup <DH Group> -CipherTransformConstants <ESP Encyprtion> -AuthenticationTransformConstants <ESP Authentication> -PfsGroup <PFS Group> -Force
    Reference:
    https://learn.microsoft.com/en-us/powershell/module/vpnclient/set-vpnconnectionipsecconfiguration?view=windowsserver2022-ps
  • AntonK
    AntonK Posts: 5
    1. So i can choose in AuthenticationTransformConstants <ESP Authentication> : MD596, SHA196, SHA256128, GCMAE192,GCMAE256, None
    and there in no such options in USG200
    PeterUK Posts: 4,729
    image  Guru Member
    edited May 2024
    Windows default phase 2 is
    encryption AES256
    authentication SH1
    PFS none
    also L2TP over IPSec IKEv1 encapsulation is Transport
  • zyman2008
    image  Master Member
    Here the string mapping between Windows and USG,
    Windows: MD596 to USG: MD5
    Windows: SHA196 to USG: SHA1
    Windows: SHA256128 to USG: SHA256
  • mMontana
    mMontana Posts: 1,506
    image  Guru Member
    According to this release from Microsoft…
    https://learn.microsoft.com/en-us/windows/release-health/status-windows-11-23h2#3291msgdesc
    Is KB5036893 installed? Or Preview update of the end of april?
    (Windows 10 is affected too, with the equivalent KB5036892)
    https://learn.microsoft.com/en-us/windows/release-health/status-windows-10-22h2#3291msgdesc
  • AntonK
    AntonK Posts: 5
    Thanks everyone for transport encapsulation and kb5036893, i've made changes and uninstall KB, and made some progress, - ZYXEL wrote that connection done, but windows think 1-2 minutes and breaks it with RasMan 809 Error
  • QuiteSmart
    QuiteSmart Posts: 75
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    image  Ally Member
    edited May 2024
    Hello, i'm having a problem in phase 1 (logs on zywall say say proposal mismatch ) this in brief is my configuration on this IKEv2 vpn:
    phase 1: encryption AES128, authentication SHA256, DH DH2
    phase 2: encryption AES128, authentication SHA256, PFS None
    THE cmdlet that i'm using in windows 10 is:
    Set-VpnConnectionIPsecConfiguration -name "MyVPNName" -AuthenticationTransformConstants SHA256128 -CipherTransformConstants AES128 -DHGroup Group2 -EncryptionMethod AES128 -IntegrityCheckMethod SHA256 -PfsGroup None -force
    do you see any error? I'm not sure about the import of the certificate, where do I have to import it?
    PS this VPN works fine with Android (strongSwan) so I suppose that the problem is in the windows client configuration. I uninstalled the KB5036892 and rebooted but nothing changed.
    ty
    image  Guru Member
    edited May 2024
    Yes you need to import the certificate are you using a self-signed certificate?
    You can look at getting a DDNS and certificate as a self-signed certificate will be fixed to 1 IP and not domain name
    will you be doing certificate mode or Enable Extended Authentication Protocol Server Mode user name and password?
