More reference incorrect
PeterUK
PeterUK Posts: 4,720 image  Guru Member
USG FLEX 200H V1.20(ABWV.0)ITS-m4447
I remove routing rules yet they still listed for ge5 after refresh
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,406 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @PeterUK
    I attempted to reproduce this issue on the USG Flex200HP, but cannot reproduce it.
    STP1. I created a test policy route and extended the References page for ge4
    STEP2. I removed the policy route.
    STEP3. I clicked the Refresh button and found the Policy Route was gone.
    Could you switch to another page and then back to this page again to recheck it? We are not sure if it is related to the browser cache issue. Thank you.
    edited May 2024
    It might have to do with the number of rules before it starts to happen
    I have tried with another browser still shows wrong
    If needed you can login to my Flex and check out the problem
  • Zyxel_Jeff
    OK, we will do it. Thank you.
