Zyxel security advisory for OS command injection vulnerabilities of GS1900/XGS1210/XGS1250
CVE: CVE-2021-35031, CVE-2021-35032
Summary
Zyxel has released patches addressing OS command injection vulnerabilities in the GS1900, XGS1210, and XGS1250 series of switches. Users are advised to install the applicable firmware updates for optimal protection.
What is the vulnerabilities?
CVE-2021-35031
An OS command injection vulnerability was identified in the TFTP client of Zyxel’s GS1900, XGS1210, and XGS1250 series of switches, such that an authenticated local user could execute arbitrary OS commands via the GUI of the vulnerable device.
CVE-2021-35032
An OS command injection vulnerability was identified in the libsal.so of Zyxel’s GS1900 series switches, such that an authenticated local user could execute OS commands via internal function calls.
What versions are vulnerable—and what should you do?
After a thorough investigation, we’ve identified the vulnerable switches for CVE-2021-35031 and CVE-2021-35032 with their firmware patches shown in the table below.
CVE |
Affected model |
Patch availability |
CVE-2021-35031 |
XGS1210-12 |
XGS1250-12 |
CVE-2021-35031 CVE-2021-35032 |
GS1900-8 |
GS1900-8HP |
GS1900-10HP |
GS1900-16 |
GS1900-24E |
GS1900-24EP |
GS1900-24 |
GS1900-24HP |
GS1900-24HPv2 |
GS1900-48 |
GS1900-48HP |
GS1900-48HPv2 |
Got a question?
Please contact your local service rep or visit Zyxel’s forum for further information or assistance.
Acknowledgments and commentary
Thanks to Jasper Lievisse Adriaanse for reporting the issue to us.
Revision history
2021-12-28: Initial release
2022-6-13: Update the patch availability in the table. Users are requested to contact Zyxel’s local support team for the standard firmware in the interim.
2022-9-1: Update the patch availability of the GS1900 series
Since I just wasted a day on this update, I thought I'd flag this here. It is from the GS1900-24HP_ReleaseNote_V270(AAHM.3)C0.pdf and it reads as follows :
Known Issue- After upgrading to firmware V2.70 or later versions from V2.60 or prior
versions, Switch will operate properly on the new firmware even though
the firmware version indicate “Unknown”. The recovery step is to reboot
the Switch and it will display the correct firmware version.
Note that this "reboot" to correct the firmware version reporting as "unknown" occurs even after rebooting with a prior firmware version and does not correct until applying the "unknown" v2.70 version from the backup image and then rebooting.
Then double check the SNMPv3 settings.0 - After upgrading to firmware V2.70 or later versions from V2.60 or prior
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
