Uncheck "Authenticate Client Certificates" from CLI on USG Flex 500 H
kaika313
kaika313 Posts: 45 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
stupidly I’ve checked "Authenticate Client Certificates" option and now I’m not able to access WEB UI. How can I disable it from CLI (SSH is enabled and working)? Or there’s something else I can do? I’ve also a configuration file before this change was made.
Thank you
Kari
Best Answers
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,499 image  Zyxel Employee
    Hi @kaika313,
    Here are the commands to disable "Authenticate Client Certificates".
    usgflex200h> edit running
    usgflex200h running config# vrf main http-server secure-server auth-client false
    usgflex200h running config# commit
    usgflex200h running config# copy running startup
    Overwrite startup configuration? [y/N] y
  • kaika313
    edited May 2024
    Hi @Zyxel_Emily,
    thank you, this solved my problem.
    I have another issue regarding SSL VPN, there’s no way to make it work. I'm using a custom port because it doesn't allow me to use same HTTPS port. Strange thing is that if I download SSL VPN configuration and use it with OpenVPN it works. If I try tu use SecuExtender (4.0.4) it doesn't work giving me these errors:
    [ 2024/05/23 16:49:15 ][SecuExtender Agent][DETAIL] SecuExtender Helper is connected
    [ 2024/05/23 16:49:15 ][SecuExtender Agent][INFO] [vpn] try to login serverpublicip:4491
    [ 2024/05/23 16:49:15 ][SecuExtender Agent][INFO] Connect to serverpublicip:4491
    [ 2024/05/23 16:49:15 ][SecuExtender Agent][INFO] Local address is localaddress
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][DEBUG] Connect success.
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 0
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][ERROR] Server unexpectedly disconnected (0x0)
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][ERROR] Error 0x80090301 querying connection info: SECPKG_ATTR_STREAM_SIZES (0x6)
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][ERROR] SSL Handshake failed. (0x6)
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][ERROR] Failed to connect to device(1) (0x6)
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][ERROR] user login device failed (0x6)
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
    [ 2024/05/23 16:49:16 ][SecuExtender Agent][DETAIL] Connection ends.
    What I'm doing wrong?
    I remember when using the previous USG40 firewall that the same problem occurred but then I was able to use same HTTPS port even if different from standard 443 and it worked. Now, using different port for HTTPS and SSL VPN it won't. Why?
    Thank you
    PeterUK Posts: 4,707 image  Guru Member
    edited May 2024 Answer ✓
    you can't use SecuExtender SSL_VPN_Client_4.0.5.0 on H models their is
    IPSec_SSL_VPN_7.7.40.019(subscription_based) or
    https://openvpn.net/community-downloads/
  • Zyxel_Emily
    Hi @kaika313,
    As PeterUK said, you need to use IPSec_SSL_VPN_7.7.40.019 (Windows) to establish SSL VPN to USG FLEX H.
