Error NAT - USG FLEX 50 (USG20-VPN)
Hi
I have a problem, I would like all users who connect from outside with port 443 to be redirected directly to my server.
I can't because I get this error directly:
Original IP cannot be set to ANY while NAT-Loopback is activated because it might cause device unreachable.
Boys, can you give me a hand with her?
So uncheck NAT-Loopback
or
make a address interface WAN1 and set for External IP
or
how you do it? Can you explain it to me or send me some guides?
You go to config > object > address/Geo IP add
name WAN1
address type INTERFACE IP
interface WAN1
then add it to you NAT rule for External IP
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
