Zywall 110 - Declare a wildcard FQDN in object?
drouboyboy
Is there a way to authorize or drop output traffic based on a wildcard FQDN?
My goal is to be able to reject all output traffic per default and authorize only output traffic that I want.
Example: I'd like to authorize all traffic to *.outlook.office.com
I've tried using Object ==> Address/Geo IP ==> wildcard FQDN but objects don't accept wildcard syntax.
Thanks.
Thanks.
Best Answers
With 4.30 or above firmware you can use FQDN type address object.
But you also can use Content Filter function to control only allow access specific web sites.
https://businessforum.zyxel.com/discussion/2230/block-all-internet-traffics-form-the-particular-device-except-some-websites#latest
6 -
Hi @PeterUK,
ZyWALL will inspect the response of DNS query to get IP addresses.
Here you can test,
1. Create a wildcard FQDN address object "*.outlook.com"
2. Create a firewall rule and select this FQDN address object as destination.
3. Query "www.outlook.com" or "autodiscover.outlook.com" from PC behind ZyWALL
4. Login ZyWALL GUI, go to Monitor > System Status > FQDN Object
You will get IP addresses what ZyWALL inspected.
Here my test,
Since there are more and more cloud based applications that could hosted on the same cloud instance(same IP address). It might block other applications with same IP address.
So that I'd prefer to use Content filter to block web request.
6
6 -
I can't see how like *.outlook.com would work for the FQDN type address object because how would it know what to lookup the IP for like test1.outlook.com or test2.outlook.com and so on?
Hi @PeterUK,
Here you can test,
Here my test,
6 -
It works also fine for me with several wildcard.
zyman2008, thanks a lot for your answer!
Seb.0 -
Still don't get how it works unless you do the request to ZyWALL? Since I have a bind server requests are done by it unless the ZyWALL transparently ever on a bridge listens for DNS queries and then maps for "*.outlook.com" FQDN address object?
Currently my understanding of FQDN address object is it pre looks up the address like for outlook.com without you doing a lookup.
Edit I think I just answered my own question! really cool how it works!
- 243 Nebula Ideas
- 6.9K Security
- 790 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 326 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
