Does XS1930-10 SFP link down to 1Gb
PeterUK
PeterUK Posts: 4,835
image  Guru Member
Does the SFP on XS1930-10 can link down to 1Gb?
thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,284
    image  Zyxel Employee
    Hi @PeterUK,
    The SFP ports of XS1930-10 support 1G & 10G, so, you can use 1G SFP or change the speed/duplex to "Auto-1G/1G full duplex" when using 10G SFP.
    In addition, the link might not be up if one of the switches has changed to "Auto-1G/1G full duplex" but another switch is still in auto speed/duplex.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    Zyxel Melen
