Zywall 110 - Declare a wildcard FQDN in object?
drouboyboy
drouboyboy Posts: 5
image  Freshman Member
edited April 2021 in Security
Is there a way to authorize or drop output traffic based on a wildcard FQDN?
My goal is to be able to reject all output traffic per default and authorize only output traffic that I want.
Example: I'd like to authorize all traffic to *.outlook.office.com
I've tried using Object ==> Address/Geo IP ==> wildcard FQDN but objects don't accept wildcard syntax.
Thanks.
Best Answers
    PeterUK Posts: 4,816
    image  Guru Member
    I can't see how like *.outlook.com would work for the FQDN type address object because how would it know what to lookup the IP for like test1.outlook.com or test2.outlook.com and so on?
  • drouboyboy
    drouboyboy Posts: 5
    It works also fine for me with several wildcard.
    zyman2008, thanks a lot for your answer!
    Seb.
    image  Guru Member
    edited February 2019
    Still don't get how it works unless you do the request to ZyWALL? Since I have a bind server requests are done by it unless the ZyWALL transparently ever on a bridge listens for DNS queries and then maps for "*.outlook.com" FQDN address object?
    Currently my understanding of FQDN address object is it pre looks up the address like for outlook.com without you doing a lookup.
    Edit I think I just answered my own question! really cool how it works!
