Flex 100 Policy Control Question
Admittedly, I've been sick for several days, and brain fog is affecting me. In addition, it's been too long since I've been in a Zyxel.
Here's my scenario: client with a Flex100 has a device on DMZ. That device now needs to have some ingress data allowed. Have the address and service objects and groups created. But think my issue is in remembering the set up for the Virtual server NAT and then corresponding policy control rule. If the scenario is: traffic from address group 1, with service group A traffic, is allowed into DMZ object IP…how do each of those look?
Thanks a ton!
    PeterUK Posts: 4,741
    image  Guru Member
    So a Virtual server NAT would be
    Incoming interface your WAN
    External IP best to make a address type interface IP of WAN
    Internal IP of the device on DMZ
    port you want to forward
    Policy Control
    From WAN
    to DMZ
    source IP if needed to limit from where
    service of port forwarded
