Unable to Establish VPN Connection
Brandix
Brandix Posts: 8
image  Freshman Member
I was recently setting up a VPN, and it turns out that when I used the wizard tool, it didn't work when executing the .bat file; it basically didn't establish a connection. I believe the problem is that the USG Flex 100 is not directly connected to the internet but to a router. Can anyone advise me on which ports or forwarding settings I should configure on the router for the VPN to work?
«1
