Zywall USG40 NAT: log internal IP on my web server
Ilix
Ilix Posts: 3  Freshman Member
edited April 2021 in Security
Hi all, my Debian server only log IP of the Zywall in LAN. What I did wrong if I want user's IP in the log?
TNX in advance. Ilic
    PeterUK Posts: 3,577  Guru Member
    You likely did a routing rule with:
    Address Translation
    Source Network Address Translation: outgoing-interface
    change this to none
  • Ilix
    Nop,  :anguished:
    In that case it's logged the IP of the server.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @Ilix
    Can you private message the configuration to me for check further?
    I will private message you later.
    Charlie
  • Jeremylin
    Jeremylin Posts: 166  Master Member
    First Answer First Comment Third Anniversary
    Is the Debian server on the wan side and you want to log internal IP?
    Better describe more about you topology.
