Transfer USG1100 config to Flex 500H
Hi @MMRHCM,
There's no configuration converter support for USG1100 to USG FLEX 500H(H series).
Zyxel Melen0
Hi @MMRHCM,
Zyxel Melen0 -
I can see why you would want it to be easy as that I had to go from Zywall 110 to FLEX200H doing lots of rule but was not as bad as I thought had to redesign part of the network due to the way I had done it but was not too bad to change.
I suggest if the USG1100 has a spare port setup a LAN to a USB Ethernet adapter login with the Flex 500H in place of the USG1100 and start over using the USG1100 as a guide.
- 245 Nebula Ideas
- 6.9K Security
- 812 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
