2 or 3 in Standalone Mode provides all features?
Best Answers
Hi @Peter5_,
Please reference our website product information to find the access point model's support features.
Roaming and mesh, in the standalone mode we call it "WDS", are supported for our access points. Below are some FAQs for you to reference.
Establishing a Reliable WDS Connection on Standalone APs — Zyxel Community
The Difference Between Roaming and Mesh in Wireless Networks — Zyxel Community
Zyxel Melen1 -
Hi @Peter5_,
I have all 3-4 APs connected with wired Ethernet. So there shouldnt be any problems?
There will be no problems with the wired connection.
And why is internet needed?
If your network is an intranet and there's no traffic from/to the Internet, then the Internet isn't needed. In addition, since our access point enables NCC discovery by default, you will find the access points try to connect to the Internet. You can disable NCC discovery to fulfill your requirement.
Zyxel Melen0
Hi @Peter5_,
Zyxel Melen1 -
I have all 3-4 APs connected with wired Ethernet. So there shouldnt be any problems? And why is internet needed?
Hi @Peter5_,
Zyxel Melen0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
