how to have access with certification enabled
If what you means is the client certificate authentication.
Then login device by serial console or SSH, and here the command to disable it.
Thanks lot for your help, the problem has been solved.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
