USG-FLEX-500H how to enable a secure policy from Console?
phphil
phphil Posts: 39
image  Freshman Member
edited October 2024 in Security
Dear zyxel community,
I've locked my self out from USG-FLEX-500H 💆‍♂️🤭
i'm now connected to device through console cable and i'm trying to figure out how to enable back the security policy i've disabled
    rule
name LAN_to_Device
enabled false
from LAN
to ZyWALL
user any
schedule any
source-ip any
destination-ip any
service any
action allow
logging no
content-filter-profile none
ssl-inspection-profile none
app-patrol-profile none
as you can see it is disabled, anyone can help me with the command enable it back?
THX
    PeterUK Posts: 4,816
    image  Guru Member
    edited October 2024 Answer ✓
    This should be it
    edit running
    vrf main
    secure-policy
    rule LAN_to_Device
    enabled true
    commit
    copy running startup
    image  Guru Member
    This should be it
    edit running
    vrf main
    secure-policy
    rule LAN_to_Device
    enabled true
    commit
