USGFLEX 50 ip-address change
MattiS
MattiS Posts: 9
image  Freshman Member
I need to change LAN ip-addresses from 192.168.10.xxx to 192.168.100.xxx
I haven't been able to find a spot where to do it?
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,756
    image  Zyxel Employee
    Hi @MattiS ,
    Please see PeterUK's recommendation firstly.
    If you still want to change your LAN IP addresses from 192.168.10.xxx to 192.168.100.xxx, you can follow these steps:
    1. Navigate to: Configuration > Network > Interface
    2. Select the LAN interface you want to modify (e.g., lan1)
    3. Update the IP address
    4. Adjust DHCP configuration if necessary
    Zyxel_Judy
  • MattiS
    MattiS Posts: 9
    I want the LAN ip addresses to be 192.168.100.xxx. F.eg. Printer address is in the old firewall 192.168.100.200, so I want the printer to be the same address in this new Flex50.
    PeterUK Posts: 4,740
    image  Guru Member
    edited October 2024
    If you have 50 devices with DHCP set for x days and you change the LAN subnet on the flex you have to reboot devices or wait x days for them to get the new IP in that subnet or change lease time to 3mins wait x days on the old lease then change the IP subnet and your devices will get a new IP in that subnet in 3 mins
    I don't recommend 192.168.100.xxx if you have a modem thats on 192.168.100.1
  • Zyxel_Judy
    Hi @MattiS ,
    Zyxel_Judy
  • MattiS
    MattiS Posts: 9
  • MattiS
    MattiS Posts: 9
    Hello!
    Thank you, for your answer, Judy!
    I did that and added a bit lower a IP Pool start address to 192.168.100.33.
    However, now I see no computers in DHCP table! Why?
    I can't fix any IP addresses now.
    Best regards, Matti
    image  Guru Member
    reboot the computers
