VPN 100
Dpj
Dpj Posts: 215
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
image  Master Member
I have an question about the VPN 100 support. Is this device end of life. When i look at the status, i can see on the status page from zyxel, the end of vulnerability support is 30-09-2023. But the latest firmware is from february 2024. Is this device EOL or not?
For example when i look for the zywall 110 (which i know its EOL), on the status page the vulnerability support is till 31-12-2022, and the RMA is till 2027. The RMA for the VPN100 is till 2025.
Especially because of the firmware update of february im not sure about the status.
yours dennis
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279
    image  Zyxel Employee
    edited November 2024 Answer ✓
    Hi @Dpj
    The VPN100 firmware update (5.37(ABFV.2)) from February 2024 was released to address specific critical CVEs, even though the end of vulnerability support date for this device was September 30, 2023. After this date, Zyxel typically does not release security fixes or vulnerability updates. However, we do make exceptions for widespread critical vulnerabilities, which is why this firmware update was issued.
    As of now, the VPN100's end of support date is set for March 31, 2025. This means while general security patches have ended, any essential maintenance updates for critical vulnerabilities may still be provided.
    Please also note that the "End of RMA & Tech Support" date may vary depending on the region. For global (except US and Taiwan) EOL information, you can check this page: https://webservice.zyxel.com/end-of-life .
    Hope this clarifies things!
    Kay
    PeterUK Posts: 4,818
    image  Guru Member
    Yes is EOL I did wish Zyxel support it for as long as the FLEX models
  • Dpj
    Dpj Posts: 215
    image  Master Member
    but why still firmware update then in 2024? do you know that?
    image  Guru Member
    Due to vulnerabilities and Exposures they did one more patch for them models
  • electsystech
    electsystech Posts: 61
    First Answer First Comment Friend Collector Seventh Anniversary
    image  Ally Member
    So are they going to issue another patch for the last vulnerabilities?
  • Zyxel_Kay
    Hi @Dpj
    Kay
