What can I do to read Terms of Use and Privacy Policy in Initial Setup Wizard of USG FLEX 500H?
I am going to setup USG FLEX 500H. I I can't read Terms of Use and Privacy Policy because my device has not connected to Internet yet.
So I cannot check "I have read and agree with the Items above" checkbox.
I'd like to read these items without connecting Internet. Will this feature be changed further firmware?
Hi @smb_corp_user,
Thanks for your support of the Zyxel community! I understand SandB's requirements. Unfortunately, it is not possible currently. Knowing the background is important so we can investigate how to improve it.
Hi @SandB,
Please reference the links below which are the same document on the device GUI's links.
Zyxel Melen1
Hi @SandB,
Could you share your scenario? In normal cases, the firewall needs to connect to the Internet, so you can register it and upgrade firmware.
Zyxel Melen0 -
Hi @Zyxel_Melen, SandB does not want to connect their USG FLEX 500H to the internet before the configuration is completed, which can only be done after checking the "I have read and agree with the Items above" checkbox, but SandB does not want to check that box before they have read the internet pages Terms of Use and Privacy Policy .
Hi, SandB. If you want to continue the setup without connecting to internet, you have to find a way to read those documents from a computer which is already connected to the internet, for example by getting the direct links to those documents from the Zyxel Support team members.
Hi @smb_corp_user,
Hi @SandB,
Zyxel Melen1
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
