How to configure dual WAN
Sure I would suggest another VLAN number depending on what you got connected like a switch to thats VLAN1 for LAN1 unless you have another VLAN like 77 untag to LAN1 and VLAN1 to tag to USG60?
so you do routing rules like
incoming LAN1
next hop WAN1
2nd rule
incoming VLAN1
next hop WAN2
Hi Peter,
Yes, we have the VLAN network on VLAN ID 2 tagged to LAN1. The devices on the VLAN seem to be picking up the DHCP correctly. But all going through WAN1 for internet.
Thank you for the advice on the Routing option. I did consider this but was unsure the correct procedure. I will give this a go next visit to site.
Many thanks !0
- 417 Beta Program
- 2.5K Nebula
- 160 Nebula Ideas
- 108 Nebula Status and Incidents
- 5.9K Security
- 331 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 259 Service & License
- 402 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 80 Security Highlight
