How to configure dual WAN
Posts: 3  Freshman Member
Hi Guys,
We have a USG60 with dual WAN and I would like to have LAN1 use WAN1 for internet and VLAN1 use WAN2 for internet. Is this possible ?
Many Thanks
Bran
  • Posts: 3,693  Guru Member
    Sure I would suggest another VLAN number depending on what you got connected like a switch to thats VLAN1 for LAN1 unless you have another VLAN like 77 untag to LAN1 and VLAN1 to tag to USG60?
    so you do routing rules like
    incoming LAN1
    next hop WAN1
    2nd rule
    incoming VLAN1
    next hop WAN2
  • Posts: 3  Freshman Member
    Hi Peter,
    Yes, we have the VLAN network on VLAN ID 2 tagged to LAN1. The devices on the VLAN seem to be picking up the DHCP correctly. But all going through WAN1 for internet.
    Thank you for the advice on the Routing option. I did consider this but was unsure the correct procedure. I will give this a go next visit to site.
    Many thanks !
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
Welcome!
