IPV6 VPN
Hi @dathing89
Could you let us know which firewall model you're using?
If you're using a ZLD-based firewall (USG/USG FLEX/ATP), you can refer to this article for a step-by-step guide on configuring IPv6 IPSec VPN:
Kay
Hi @dathing89
Kay
Many thank's for your help !
We try to "mount" an ipsec VPN between 2 site over Starlink. This provider use CGNAT router, so 500 and 4500 port are not allowed.
But we discover that Starlink provide IPV6 IP without NAT…
Is it possible to create an IPV6 tunnel with IPV4 Lan on each side ?
Many thank's again
L.
Hi @dathing89
Using an IPv6 tunnel with IPv4 LANs on each side is technically feasible but not recommended due to potential routing issues. The separation between IPv4 and IPv6 stacks can make traffic management and routing complex.
Kay
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 390 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
