Disable sending LLDP to ISP over fiber link
Hi
Sorry for my intensive posting. I am new on modern Zyxel switches and syntax differs a little bit against what I am used to :) Trying to make sure the new Zyxel switch will do what I expect it to before make it production active.
Instead of doing this on the fiber port interface to the ISP…
no lldp basic-tlv management-address
no lldp basic-tlv port-description
no lldp basic-tlv system-capabilities
no lldp basic-tlv system-description
no lldp basic-tlv system-name
no lldp org-specific-tlv dot1 port-vlan-id
no lldp org-specific-tlv dot3 mac-phy
can I use...
lldp admin-status rx-only
or
lldp admin-status disabled
And be *sure* no lldp is sent out to the ISP?
Tnx in advance
//Peo
Hi @peos42
Yes, you can use the
lldp admin-status rx-onlycommand to configure the interface to only receive LLDP packets, orlldp admin-status disabledto ensure that the interface neither sends nor receives LLDP packets. Both options will prevent LLDP packets from being sent to your ISP.If you prefer a graphical approach, you can adjust these settings via the web interface. Simply navigate to PORT > LLDP > LLDP Setup to modify the LLDP configuration for the specific interface.
Kay
Hi @peos42
Kay
Tnx for the reply. I was a little bit confused because it was named "no lldp" on the switch level, but on the interface level the ekvivalent was "lldp admin-status disabled".
But I will probably go for just receiving with "lldp admin-status rx-only" from the ISP on the fiber port :)
Tnx @Zyxel_Kay
Hi @peos42
On the interface level, there are four options for the LLDP admin status:
disabled,tx-only,rx-only, andtx-rx. Using the commandlldp admin-status disableddisables LLDP entirely for that specific interface.At the switch level, however, the
no lldpcommand is used to disable the LLDP function globally for the entire switch.I hope this clears up the confusion! Feel free to reach out if you have any more questions.
Kay
Yes. Now it is clear to me. It is just ZynOS that confuses me a bit. I would have expected "no lldp" on the interface level as well and not a different syntax like "lldp admin-status disabled" as it has the same meaning as "no lldp". I think disabling it on the switch and the interface would be the same syntax.
I also had problem to find "shutdown" and "no shutdown" on the interface, but just after looking for it, I saw you named if differently (inactive).
But… I am getting used to it. Working on it 🙂
Tnx
- 235 Nebula Ideas
- 6.8K Security
- 737 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 90 About Community
- 117 Security Highlight
