Problems with Version V1.30(ABXF.1) USG FLEX 100H
Hello, after upgrading 2 USG FLEX 100H devices from version 1.20 to V1.30(ABXF.1) there are multiple problems.
1.- Performance-bandwidth problems (The client has 1G internet access on the WAN and we only have 100M from LAN to WAN
2.- Sessions and traffic are not shown in the logs or Dashboard
3.- Traffic cannot be seen in the logs.
4.- Traffic between WAN and LAN is slow.
This is a big problem for my client and I need to resolve it as soon as possible.
Thank you.
Hi @Pedroj
To better understand and investigate the issues you're experiencing, it would be helpful if we could access your firewall remotely via the web GUI.
You can follow the steps in this guide to enable HTTPS Web GUI access from the WAN:
How to allow HTTPS Web GUI Access from WAN? (USG FLEX H) — Zyxel Community
Once enabled, please share the login credentials for your device with us via a private message.
Kay
See how you've made an impact in Zyxel Community this year!
Hi @Pedroj
Thank you for sharing the remote web GUI details via private message. We're still investigating your issue.
In the meantime, we would greatly appreciate it if you could provide us with the following additional information:
- How did you test the performance?
- What were the performance results before upgrading to version 1.30P1?
- Does the 1G internet access on the WAN refer to the ge1_PPP interface?
Kay
We tested the performance by connecting only one PC directly to the Firewall.
Before the 1.30P1 update, the client had the maximum ISP speed.
800M symmetrical and even more.
Yes, the 1G access is PPoE.
WAN2 is 4G
Could you send me version 1.20 to try to give him a quick solution if the solution takes a while?
The client is very upset.0 -
Hi @Pedroj
As discussed in our private messages, we’ve identified that both the throughput and session issues were caused by NAT rules. This fix will be included in an upcoming official firmware release, scheduled for early 2025.
Kay
Hello Zyxel team,we have the same problems as @Pedroj with an "usgflex100hp".
The problems have been there since purchasing the USG in May 2024, even with the older firmware versions.
The following is the current system information:
Host Name: usgflex100hp
Firmware: V1.30(ACII.1) | 2024-11-08 07:32:53
Uptime: 15 days, 19:25:24
System Time: 2025-01-08 11:30:52
Boot Status:OK
Problem A: Session monitor: "0/300000" is always 0, so the session monitor has "no data".
Problem B: Throughput and performance primarily with Zoom and Teams sessions
Question: Will these problems ALSO be resolved for the usgflex100hp with the new firmware version announced at the end of January?
Thank you very much for an answer and a solution
Hi @Gruenauer
I’ve sent you a private message regarding the next steps. Please check your Community inbox for the details.
Kay
Yes, hello Kay, thanks,but I'm having trouble downloading; The zip isn't completely downloaded.
Question: Is the 130ACII1ITS-24WK47-m6271.zip the right file?
I've already installed "Firmware: V1.30(ACII.1) | 2024-11-08 07:32:53"?
Thank you for your first quick reaction?
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 272 USG FLEX H Series
- 274 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 392 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 74 Security Highlight
