V1.31 not stable to the UI
FLEX200H V1.31
Short uptime and I get this
Same here
and here USG FLEX 500H ….. no comment
At the end…We rebooted the device and now, maybe for a while, it works correctly.
Yup its what I had to do reboot it and it happened again😣 so around 24hr later
Hi users,
We have been unable to reproduce this issue in our test environment with our configuration. To help diagnose the problem, we need direct access to your device through WAN.
Please follow the steps below to set up WAN access, then send the access credentials via private message (click my account > Message).
Steps to configure your device to allow access from Zyxel HQ IP addresses:
118.163.48.105
61.222.75.14
You can refer to the below link to see how to configure it:
USG / USG FLEX / ATP / VPN - How to allow HTTPS Web GUI Access from WAN? – Zyxel Support Campus EMEA
Then providing the device access URL or IP address, login account with admin privilege, login password to us.
it works for me, my Flex200H is up still 2 days
Ok thanks, i sent a private message to you. You should consider that after the reboot i did't see others similar issues
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
