Problem with XGS1930-52 and SFP10G-T
Hallo,
i have inserted a Zyxel SFP10G-T SFP+ Module into a XGS1930-52 on Port 50 (also tried other ports already) and tried to connect to XMG1930-30HP on the 10G Port.
But no chance to get a connection.
All switches are Nebula managed and running the latest firmware assigned by Nebula.
Do someone have a hint?
Thx
Hi @Venta,
What's your firmware version? Could you set the link speed to 10G/Full Duplex on XGS1930-52 to test first?
Zyxel Melen0 -
Do i really have to set as Media Type here DAC10G?
We are speakting about the module SFP10G-T from Zyxel.0 -
No, SFP10G-T is SFP module, not DAC. Therefore, you don't need to change the media type option.
Zyxel Melen0 -
I have already tried, but did not work. There should be a blue light on the module which is there for a short time when rebooting the switch and the DDMI information that the module is present is also there.
But no successful connection, not even 1G to the XMG1930-30HP. The cable length is approx. 60m. The XMG diagnostics tells me the length.
Thx.
Hi @Venta,
I want to share with you that the Maximum distance of SFP10-T is 30M.
If your cable is 60M, the link will not be up. Please consider the fiber SFP module in your topology.
Zyxel Melen0
- 234 Nebula Ideas
- 6.7K Security
- 723 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
