How to let the web ui of zywall only accessable by using only one domin zone
JiangNanGenius
JiangNanGenius Posts: 6
image  Freshman Member
edited April 2021 in Security
How to set a limitation. To only use one domain zone like it.XXX.com instead accessible from all domain that binded with the IP-address
  • JiangNanGenius
    i'm using a zywall 110
  • Ian31
    Ian31 Posts: 174
    image  Master Member
    You can only grouping the FQDN objects (host1.it.xxx.com, host2.it.xxx.com, ...).
    Wildcard(*.it.xxx.com) is not possible as source, since "*" means unknown.
  • JiangNanGenius
    @Ian31 Thanks a lot for your reply. But actually the problem is i cannot find the option
  • Ian31
    Ian31 Posts: 174
    image  Master Member
    Sorry, I think I misunderstood what you want.
    Do you want to limit the source IP that can access the device GUI ?
    or want to limit the device GUI binding FQDN ? (like a virtual host of web service)
  • JiangNanGenius
    @Ian31   Accutally i want to limit the device GUI binding FQDN. Like using nas.xxx.com to only my nas   remote.
  • JiangNanGenius
    @Ian31 Thanks a lot it's working
