Problem with XGS1930-52 and DAC10G-1M
Hi @Venta,
Could you set the link speed to 10G/Full Duplex on both switches to test first?
Zyxel Melen0 -
Hallo,
i have tried to set the Link speed to 10G/Full Duplex on one side, but it did not work.
Do i have to set it on both sides?
Thx
Update:
The reason for the auto-negotiation links to 1G is that Nebula pushes the wrong link speed configuration. This has been corrected, if anyone hasn't fixed your port to 10G, please change the port setting so Nebula will push the correct configuration to your device.
Zyxel Melen0 -
Well… According to this…
Nebula service is built to asks the users to solve the things done wrong by Nebula team?
I'd suggest to publish an advisory for that, both on community and nebula dashboard.
If Zyxel is going "Cloud only" for the devices… I will quit buying zyxel devices and advise against buy it.0 -
Hi @mMontana,
to asks the users to solve the things done wrong by Nebula team?No. We decided not to push the correct configuration because, although it might be short, it could cause network downtime for other users.
Thanks for your input. I have shared it with our product team.
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
