ZyXEL Configure Converter VPN100 to Flex200
Hi
Noticed at:
convert.cloud.zyxel.com
I can convert VPN100 only to Flex 200H or Flex200 HP.
I happen to have Flex 200. Is there a way to have my VPN 100 configuration converted to Flex 200?
You're correct. There are no tools or workarounds available to convert the configuration from VPN100 to FLEX200.
Zyxel_Judy
Hi @Rimfire ,
The Zyxel Security Appliance Configuration Converter helps convert configurations from:
- Legacy appliances (USG/ZyWALL) to newer ZLD firmware devices
- VPN/ATP/USG FLEX to the latest uOS firmware (USG FLEX H series)
Please note that there is no tool available to convert configurations from VPN to USG FLEX.
Zyxel_Judy
Thanks,
just to be sure:
1. There isn't a converter for VPN100 to Flex200?
2. There isn't a work around to convert the VPN100 konfiguration to Flex200?
The plan is to skip Nebula mode due to complexity of the configuration.0 -
Has it never existed, or did it exist some years ago (before H series)?
Zyxel_Judy
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
