Register new unmanaged switches in portal.myzyxel.com
GiuseppeR
GiuseppeR Posts: 782
image  Guru Member
Hello everyone,
I tried to register also some unmanaged Zyxel switches on portal.myzyxel.com but there I see that it is requested to have both serial number and MAC address.
So is it impossible to register on portal.myzyxel.com all the unmanaged switches?
Thanks in advance
    PeterUK Posts: 4,819
    image  Guru Member
    Being that they are unmanaged there is no firmware to download and does not get a IP from the network
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,224
    image  Zyxel Employee
    Hi @GiuseppeR,
    If you're worried about the warranty, our RMA system will check your serial number for the warranty status. You don't need to register the device to have a warranty. "portal.myzyxel.com" is to assign licenses for on-premise/standalone devices, not for warranty service.
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    Hi @Zyxel_Melen
    I was looking for a portal where to register all the serials related to products I installed for different clients, like I can do with Nebula/on-prem devices.
