List of compatible cellular sticks for USG Flex
Hi @Tzunami,
USG FLEX only supports USB storage, it doesn't support USG cellular dongle.
Zyxel Melen0 -
My old USG 200 supports a Mobile Broadband USB Dongle (it was an old 3G dongle) and the FLEX has the same options
Hi @Tzunami,
Thanks for your update. It seems like my information is incorrect. I will check with our engineer and keep you posted.
Zyxel Melen0 -
Its the Flex H models that don't support cellular dongle at this time.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
