Unable to remove user with no reference
PeterUK
PeterUK Posts: 4,131 image  Guru Member
edited March 21 in USG FLEX H Series
USG FLEX200HV1.31(ABWV.0)ITS-0311-GUI
Can't remove users with no reference might be due to long uptime on this firmware?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @PeterUK ,
    We have confirmed the issue with your 200H and will address it in the next official firmware release.
    Zyxel_Judy
    Untitled Image
  • Asgatlat
    Asgatlat Posts: 115 image  Ally Member
    First Comment Friend Collector Eighth Anniversary
    is the user a member of a group ?
    if yes, you have to remove it from the group before trying to delete the user
    no not in a group
  • Zyxel_Judy
    Hi @PeterUK ,
    Zyxel_Judy
    Untitled Image
