XGS2210-28 V4.50(AAZJ.0): VLAN configuration via console broken?
Hello!
We need assistance for configuring VLANs via console:
Enabling VLAN TX tagging does not work for us when using the console, while it works well using the web interface.
Example:
Interfaces 21-24 shall be configured for VLAN tagging. They are already configured for frame-type tagged:
interface port-channel 21
name Tagged1
pvid 10
ingress-check
frame-type tagged
green-ethernet auto-power-down
green-ethernet short-reach
exit
interface port-channel 22
name Tagged2
pvid 10
ingress-check
frame-type tagged
exit
interface port-channel 23
name Tagged3
pvid 10
ingress-check
frame-type tagged
exit
interface port-channel 24
name Tagged4
pvid 10
ingress-check
frame-type tagged
exit
name Tagged1
pvid 10
ingress-check
frame-type tagged
exit
name Tagged2
pvid 10
ingress-check
frame-type tagged
exit
name Tagged3
pvid 10
ingress-check
frame-type tagged
exit
name Tagged4
pvid 10
ingress-check
frame-type tagged
exit
But when I try to remove those ports from the untagged list in the VLANs, the changes are ignored:
$ ssh admin@coreswitch25
admin@coreswitch25's password:
Copyright (c) 1994 - 2017 Zyxel Communications Corp.
coreswitch25# show vlan 20
802.1Q VLAN ID : 20
Status : Static
Elapsed Time : 0:40:28
Port Information Mode
1 Untagged
2 Untagged
19 Untagged
20 Untagged
21 Untagged
22 Untagged
23 Untagged
24 Untagged
25 Tagged
26 Tagged
27 Tagged
28 Tagged
Default Gateway : xxx.xxx.xxx.xxx
coreswitch25# config
coreswitch25(config)# vlan 20
coreswitch25(config-vlan)# untagged 1-20
coreswitch25(config-vlan)# exit
coreswitch25(config)# exit
802.1Q VLAN ID : 20
Status : Static
Elapsed Time : 0:41:12
1 Untagged
2 Untagged
19 Untagged
20 Untagged
21 Untagged
22 Untagged
23 Untagged
24 Untagged
25 Tagged
26 Tagged
27 Tagged
28 Tagged
coreswitch25# exit
802.1Q VLAN ID : 20
Status : Static
1 Untagged
2 Untagged
19 Untagged
20 Untagged
21 Untagged
22 Untagged
23 Untagged
24 Untagged
25 Tagged
26 Tagged
27 Tagged
28 Tagged
802.1Q VLAN ID : 20
Status : Static
1 Untagged
2 Untagged
19 Untagged
20 Untagged
21 Untagged
22 Untagged
23 Untagged
24 Untagged
25 Tagged
26 Tagged
27 Tagged
28 Tagged
coreswitch25# exit
When I edit VLAN 10 in the web interface and check the "TX Tagging" box for interfaces 21-24, and compare downloaded config files before and after this edit, a diff shows that this one and exact change has been made and nothing else:
Before:
vlan 20
name LAN
normal ""
fixed 1-2,19-28
forbidden 3-18
untagged 1-24
exit
name LAN
normal ""
fixed 1-2,19-28
forbidden 3-18
untagged 1-24
exit
After:
vlan 20
name LAN
normal ""
fixed 1-2,19-28
forbidden 3-18
untagged 1-20
exit
name LAN
normal ""
fixed 1-2,19-28
forbidden 3-18
untagged 1-20
exit
Also downloading the config, changing the untagged list, and re-uploading the config, does the trick successfully.
Am I missing something or did I hit a firmware bug?
Also I am quite confident that this problem did not exist in FW 4.40.
Best regards,
// Veit
Best Answers
I am sorry, I just realised that a new untagged line will not replace the old one, so I need to use no untagged to remove ports from the list instead.
Hi @Veit
Welcome to Zyxel Community
The "frame-type tagged " means the port can receive the tagged packet only
It does not mean the port is tagged or untagged
If you want to check the port is tagged or untagged, you have to check "show vlan"
If you want to change the port is tagged or untagged, you have to type
Configure> VLAN (number) > untagged/no untagged (port number) then you can change it.
Therefore, according to your reply, it seems like the problem has been solved.
Is there any other support you need?
Sincerely,
Zyxel_Derrick5
Hi @Veit
Sincerely,
Zyxel_Derrick5 -
No, thank you, my problem is solved.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
