V1.31 not stable to the UI
    PeterUK Posts: 4,737
    image  Guru Member
    edited January 2025
    Good hope it fixes my issue too @Mk88_it
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,110
    image  Zyxel Employee
    Hi @PeterUK,
    We released a new date code firmware for this issue. I will send it to you via private message. Please help to check your message box.
    Zyxel Melen
    image  Guru Member
    Thanks installed now will monitor over a week but should see if its fix in the next 48hr
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    I just installed the same firmware
    image  Guru Member
    Sorry to report this did not fix the problem.
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    @Zyxel_Melen in my case, no more errors were displayed in the gui after 7 days of uptime
  • Zyxel_Melen
    Hi @Mk88_it,
    Thanks for your update~ 🤗
    However, we will keep checking with PeterUK about this issue.
    Zyxel Melen
    image  Guru Member
    When you left the error now currently shows
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    @PeterUK We are in the same boat. @Zyxel_Melen The errors reappeared with ITS0310 firmware
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,745
    Hi users,
    The firmware version 1.32P0, that includes the solution, has been released today.
    Please download the latest firmware version and upgrade your device. If you encounter any issues after upgrading, kindly create a new post so we can track problems specifically related to the 1.32 firmware version.
    Zyxel_Judy
