Unable to browse websites hosted on my LAN
The 110 has the new (to me) Security Policy Control. I've tried several permutations, but I can't seem to get the right rule to let me see the hosted sites from inside my LAN.
Here are the NAT rules:
Here are the policy rules:
I tried about 26 or 27 different permutations of the SERVER_REVERSE_PROXY rule with no luck. The websites work fine from the WAN.
Thanks in advance!
Hi @Hector
The reason is because NAT loopback function did not enabled.
Due to you access to server from LAN side, so NAT loopback function is required.
It’s happy to know we found the reason of it.
I changed the policy control rule as you suggested like so:
I'm still unable to browse websites from my LAN. The new Email_IMAP rule is working as I expected. This one is so strange!
Any other ideas?0 -
Hi @Hector
It’s strange situation, due to your mail server is working correctly.
I will send you private message for check this situation more details.
You could try IPv4 to any and see if that works
Are you using the newest firmware?
Both NAT and Security Control rules are IPV4.
I'm using firmware version V4.33(AAAA.0). As far as I can tell, that the latest for Zywall 110.0 -
Hi @Hector
Looking at your screenshots you cannot have “Enable NAT Loopback” setting enabled with “External IP” set to “any”.
Make a address rule with type “INTERFACE IP” for “wan1” and set that for “External IP” and check “Enable NAT Loopback”.
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
