700H set SFP vlans to "Tagged"?
jef
jef Posts: 87  Ally Member
700H multiple vlans on a 10G sfp uplink.
How or where do I make sure the SFP Port p14, is "tagged"..
I do not see tagged or untagged anywhere, under the internal interfaces.
I see "Trunk", but that appears to be WAN only.
This 10G sfp is an uplink to a switch, with multiple vlans on the switch and the same vlans configured on the 700H and all bound to the same p14.
    PeterUK Posts: 3,887  Guru Member
    Any VLAN you make is tagged
  • jef
    That would make sense. Thank You!
