Does USGFLEX100AX support software VPN clients?
Jmax77
Jmax77 Posts: 3
image  Freshman Member
The last step in choosing my equipment upgrade is whether it supports software VPN clients like OpenVPN. This device is already recommended for my VOIP system; but I need to know I can easily connect devices remotely and without additional hardware.
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,010
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 500 Comments
    image  Zyxel Employee
    Hi @Jmax77,
    Welcome to Zyxel Community!
    The USG FLEX 100AX supports software-based VPN clients, such as
    • Windows Native VPN
    • Zyxel SecuExtender
    However, OpenVPN is not supported on the USG FLEX 100AX. This protocol is only available on the USG FLEX H series.
    Zyxel Tina
  • Zyxel_Tina
    Hi @Jmax77,
    Zyxel Tina
  • Jmax77
    Jmax77 Posts: 3
    I have no trouble getting the SecuExtender to connect. Windows native VPN will not. How should I have the VPN connection configured in the Windows 11 VPN native client? Does Windows require L2TP? I've managed to get this gadget all set up with very little help- which is demonstrative of the simplicity of the Nebula system. I'm just at the very last stages of getting everything working.
    PeterUK Posts: 4,738
    image  Guru Member
    edited August 2025
    Yes Windows 11 VPN native client does work depending on how you set it up
    like for L2TP/IPsec with per-shard key you need to setup as IKEv1 Phase 1 with Phase 2 Encapsulation Transport then you need to setup the Phase 1 and Phase 2 Proposal windows defaults but can be change by here for more info here
    https://learn.microsoft.com/en-us/powershell/module/vpnclient/set-vpnconnectionipsecconfiguration?view=windowsserver2022-ps
    Phase 1
    3DES SHA1
    key group DH2
    Phase 2
    Local policy 0.0.0.0
    AES256 SHA1
    PFS none
