IP/MAC Binding on Flex H series
QuiteSmart
QuiteSmart Posts: 79
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
image  Ally Member
Hello community,
is it possible to configure IP/MAC binding as it is in the "interface" settings of the ATP GUI?
I cannot find it, nor on-premise nor in the nebula configuration
I found a more or less recent FAQ about MAC binding here but it just refers to the ATP GUI.
Thanks😜
    PeterUK Posts: 4,842
    image  Guru Member
    edited August 2025 Answer ✓
    So tested it out seems to work "Source IP Spoofing Prevention" where by any static IPs are blocked unless allowed by Trusted IP.
    and any Reserved IP/MAC that you make static are allowed even if not in Trusted IP but with Include DHCP Leasing Entries on
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,302
    image  Zyxel Employee
    Hi @QuiteSmart
    This feature is renamed as "IP Spoofing Prevention."
    FAQ: USG FLEX H Series - Source IP Spoofing Prevention — Zyxel Community
    Zyxel Melen
  • QuiteSmart
    image  Ally Member
    Then you @Zyxel_Melen ,
    does it work even when some mac addresses have the IP locked with DHCP reservation?
    image  Guru Member
    edited August 2025
    guess thats what the "Include DHCP Leasing Entries" toggle is?
    unless your looking for this?
  • QuiteSmart
    image  Ally Member
    Hello @PeterUK I hope you had/are having nice vacations,
    I must admit that since @Zyxel_Melen reply I still have to test it
    What I would like to get is the following:
    1. DHCP is on that interface
    2. I have some devices with DHCP reservation in place (like in @PeterUK screenshot)
    3. In case a host connects with DHCP he is alllowed
    4. In case a host connects with a static IP it is banned and log alert reported
    5. Hosts with DHCP reservation are allowed and DHCP reservation takes place
    6. Eventually (since i saw something that seems alike) i can whitelist some ip addresses (in case a host presents itself with that static IP it is allowed)
    It seems to me that everything can be done I just wanted to double check on the DHCP reserved hosts since AFAIK on ATP series they were not allowed in such a scenario
    image  Guru Member
    SO your looking for the "Enable IP/MAC Binding and DHCP Enforcement" ?
    image  Guru Member
  • QuiteSmart
    image  Ally Member
    your "guru member" status is well deserved, thank you mate!
